jake
Scripting a Report
I am trying to script a report that can be run on a weekly basis showing yields.  I have been able to make all my charts I need, I just want to organize them so they are all on one page and save it as a .pdf so I can send it to non-jmp users to read.  I can do what I am trying to do manually by creating a journal and organizing the charts how I want them and saving the journal as a .pdf, but I can't find a way to script it.  Any ideas?ri
11 REPLIES 11
jake
Re: Scripting a Report
Perfect.  Thank you for all your help.
tart22
Pls...Jake or MS..............How can I create a script to generate the report/charts and save it as a HTML file in windows 7
for example as above for pdf
nw << save pdf("path/sheetbox.pdf");
for:
nw << save html("path/sheetbox.html");
path=C:\Users\tat\Documents\bk
sheetbox=pc+rm chart.html
Thanks.
