Arkawa
Script to rename a table coming from the Contingency Table option : Make Into Data Table
Hi all,
I made a code to obtain a data table with contingency table tool information, unfortunately, the table issued is named "Untitled xxx". I would like to know if by scripting it will be possible either to select the last table created and change its name, or to select the table containing Untitled in its name, to rename it at the end ?
The objective is to close the table at each launch if the script to avoid having several tables.
I tried to use Current Data Table () function but it does not work properly (another table is selected).
The code section :
Contingency(
	Y( :"Pass/Fail"n ),
	X( :Task ),
	Contingency Table(
		Count( 1, Format( "Fixed Dec", 2, 0 ) ),
		Total %( 1, Format( "Fixed Dec", 2, 2 ) ),
		Col %( 1, Format( "Fixed Dec", 2, 2 ) ),
		Row %( 1, Format( "Fixed Dec", 2, 2 ) ),
		Expected( 0, Format( "Best", 3 ) ),
		Deviation( 0, Format( "Best", 3 ) ),
		Cell Chi Square( 0, Format( "Fixed Dec", 2, 4 ) ),
		Col cumulative( 0, Format( "Fixed Dec", 2, 0 ) ),
		Col cumulative %( 0, Format( "Fixed Dec", 2, 2 ) ),
		Row cumulative( 0, Format( "Fixed Dec", 2, 0 ) ),
		Row cumulative %( 0, Format( "Fixed Dec", 2, 2 ) )
	Mosaic Plot( 0 ),
	Make Into Data Table,
Thank you !
Best regards
4 ACCEPTED SOLUTIONS
Re: Script to rename a table coming from the Contingency Table option : Make Into Data Table
I'm not sure if you can do if within just that one command, but I think you can send the Make Into Data Table message to the CrossTabBox
cont = dt << Contingency(
	Y(:Age),
	X(:sex),
	Contingency Table()
dt_cont = Report(cont)[OutlineBox("Contingency Table"), CrossTabBox(1)] << Make Into Data Table;
and for that you can get the reference
Arkawa
The code works as follows :
dt_cont << Set Name("Contingency Table");
:) Thank you !
You need to use
dt_cont << set Name("Contingency Table")
Few different options doing this. Here is one using loop to go over different references you get from Contingency platform when using By column
conts = dt << Contingency(
	Y(:height),
	X(:age),
	By(:sex)
Show(conts); // two references
dt_conts = {};
For Each({cont, idx}, conts,
	groupname = Word(-1, Report(cont)[OutlineBox(1)] << get title, "=");
	dt_cont << Set Name("Contingency Table " || groupname);
	Insert Into(dt_conts, dt_cont);
8 REPLIES 8
	Y(:Age),
	X(:sex),
	Contingency Table()
Arkawa
Hi jthi,
Thanks for your prompt answer. However, even if I add :
dt_cont << Data Table(Name("Contingency Table"))
I obtain the same result, the new data table is named as "Untitled XXX" (without code error).
Best regards
Arkawa
:) Thank you !
You need to use
Arkawa
Hi all,
I would like to upgrade my code, when I generate the Contingency Analysis, now I have two analyzes one named "1" and the second "2", I would like to make the same way to obtain two data tables at the end.
I tried to change the code as follows:
dt << Contingency(
    Y( :"Pass/Fail"n ),
    X( :Task ),
    By( :X ),
dt_cont1 = Report("Contingency Analysis of Pass/Fail By Task X=1")[OutlineBox("Contingency Table")][CrossTabBox(1)] << Make Into Data Table;
dt_cont1 << Set Name("Contingency Table 1");
dt_cont2 = Report("Contingency Analysis of Pass/Fail By TaskX=2")[OutlineBox("Contingency Table")][CrossTabBox(1)] << Make Into Data Table;
dt_cont2 << Set Name("Contingency Table 2");
But it didn't work and I don't find the solution.
Thank you in advance !
Best regards
Arkawa
The error message is :
"object not subscriptable at row XXX in access or evaluation of 'Report("Contingency Analysis of Pass/Fail By Task X=1")[/*###*/Outline Box("Contingency Table")]', Report("Contingency Analysis of Pass/Fail By Task X=1")[/*###*/Outline Box("Contingency Table")]
	Y(:height),
	X(:age),
	By(:sex)
dt_conts = {};
Arkawa
Waaaaah jthi, thank you !
It is very complicated ^^' but it works as well :)
Thank you so much !
