EV1976
Script to create a summary table with filters
Hi all
I have a data table with some numerical columns (VAL1, VAL2) and some char columns (CATEG1, CATEG2, CATEG3).
I want to write a script to crete a summary table reporting the average value of each numerical value grouped by "CATEG1,23"; this easily done:
Data Table( "MyTable" ) <<
Summary(
Group(
:Lot,
:Name( "CATEG1" ),
:Name( "CATEG2" ),
:Name( "CATEG3" ),
Mean( :VAL1),
Mean( :VAL2),
Freq( "None" ),
Weight( "None" ),
However, I'like also to filter the results according to CATEG1,2,3: e.g. to include only results with CATEG1=="Standard".
I tried brutally inserting a "where" clause, but it doesn't seem to wiork
  where(:CATEG1 == "Standard")
I know that this can be easily done interactively, but I'd like to do it via script.
Thanks
EV1976
Re: Script to create a summary table with filters
By filtering do you mean you want to delete other rows? If this is the case:
Using Big Class.jmp as example table. Leaving only rows with have :sex value of "M" to summary table
wait(1);
dt_summary = dt << Summary(
	Group(:age, :sex),
	Mean(:height),
	Mean(:weight),
	Freq("None"),
	Weight("None"),
	Link to original data table(0)
wait(1);
dt_summary << Delete Rows(dt_summary << Get Rows Where(:sex != "M"));
Using tabulate might also be a good option. You can use local data filter or directly add Where (what I'm doing here)
wait(1);
tab = dt << Tabulate(
	Show Control Panel(0),
	Add Table(
		Column Table(Analysis Columns(:height, :weight), Statistics(Mean)),
		Row Table(Grouping Columns(:sex, :age))
	Where(:sex == "M")
Scripting index has quite good suggestions:
Delete Rows:
Get Rows Where:
Select Where:
wait(1);
	Group(:age, :sex),
	Mean(:height),
	Mean(:weight),
	Freq("None"),
	Weight("None"),
wait(1);
wait(1);
	Add Table(
	Where(:sex == "M")
Delete Rows:
Get Rows Where:
Select Where:
EV1976
Both solutions work for me.
"Tabulate" option suits perfectly my needs
Thank you very much
EV1976
