shampton82
Script to control the Profiler
I like adding buttons to my toolbar that run scripts that execute actions of common tasks I do vs having to dive multiple layers into an option menu.  My most recent goal is to add some buttons that would control steps i take in the profiler.  Specifically I'd like to click a button to have the profiler maximize desirability, one for set the profiler to a row, and one to save current profiler settings.  However, I couldn't find any syntax in the scripting library to work from.
So for exact details on what I'm trying to accomplish this is a description for the Max desirability button:
1.  Run an analysis 2. Create a prediction profiler 3.  Pred Pro red arrow-> add desirability 4. Adjust desirability 5. **Click button on toolbar with my macro to maximize desirability**
Thanks for any ideas!
Steve
Re: Script to control the Profiler
I do not see a way to send messages to the Prediction Profiler that is embedded in any fitting platform. The only messages I found are the ones that open or close it.
fit << Profiler( 1 );
fit << Profiler( 0 );
Maybe someone else knows how to send messages to the embedded object that accomplish the same tasks as the commands in the red triangle menu.
So you have to include the necessary arguments to the message that opens the profiler to get what you want. Here is an example:
launch = dt << Fit Model(
	Y( :weight ),
	Effects( :age, :sex, :height ),
	Emphasis( "Minimal Report" )
fit = launch << Run;
fit << Profiler( 1,
	Confidence Intervals( 1 ),
	Desirability Functions( 1 ),
	Term Value(
		age( 12, Lock( 0 ), Show( 1 ) ),
		sex( "F", Lock( 0 ), Show( 1 ) ),
		height( 62.55, Lock( 0 ), Show( 1 ) )
MathStatChem
This will get a reference to the profiler
pf = report(fit)["Prediction Profiler"] << get scriptable object;
Then you can send messages to the profiler, e.g.
pf << Maximize Desirability;
shampton82
Thanks for all the help!  Between these suggestions and this help from Jordan Hiller:
"Yes, you can get a reference to an already-open analysis. For example, this script will add a Press report to an open Fit Model:
//Get ref to fit least squares object
fm = Current Report()[Outline Box( 1 )] << Get Scriptable Object;
//show press report
fm << Press( 1 );"
I have this script which works great, is now in my toolbar and  saving me clicks!
dt=current data table();
pf = Current Report()["Prediction Profiler"] << get scriptable object;
