nikles
Save To Tall/Wide Spec Limits Table
Hi.  I'm interested in saving the limits of a table to a new table using the "Save to tall spec limits table" or "Save to wide spec limits table" feature.  However when I try it, nothing happens.
Names Default to Here(1);
msl = dt << Manage Spec Limits(Y(:PNP1, :NPN1, :PNP2));
dtlim = msl << Save to Tall Limits Table;  //Nothing happens
Does anyone know how to use this command?  The Scripting Index entry for this command is empty, so not sure where else to go but here.
Thanks!
Re: Save To Tall/Wide Spec Limits Table
The command is "Save to Tall Spec Limits Table" and not "Save to Tall Limits Table".
The following code should work:
dt = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" ); //open data
obj = dt << Manage Spec Limits( Y( dt << Get Column Group( "Processes" ) ) );
dttall = obj << Save to Tall Spec Limits Table;
I was not able to get it to work, but this will create the table
report(msl)[buttonbox(2)]<<click;
ThuongLe
Hi nikles,
you can take a look at this post:
3 ways to load your specification limits into Process Capability
And this post:
Manipulating and managing your specification limits
Thuong Le
nikles
Oof. My mistake. Thanks Tonya.
