robot
Save Journal overwrites graphs of Fit Group
Sending Save Journal command to Fit Group appears to overwrite each row of graphs rather than saving the entire journal.  Is this a bug or am I doing something wrong?
JMP 17.2.0
biv = dt << Fit Group( Bivariate( Y( :height ), X( :weight ) ), Bivariate( Y( :weight ), X( :height ) ), <<{Arrange in Rows( 2 )}, By( :Age ) );
journ = biv << Journal;
save_dir = Pick Directory( "Select a directory" );
journ << Save Journal( Concat( save_dir, "Big Class.jrn" ) );
Re: Save Journal overwrites graphs of Fit Group
Few options
biv = new windoW("",dt << Fit Group(
	Bivariate(Y(:height), X(:weight)),
	Bivariate(Y(:weight), X(:height)),
	<<{Arrange in Rows(2)},
	By(:Age)
biv << Save Journal("$TEMP/test.jrn");
Open("$TEMP/test.jrn");
Or
	By(:Age)
biv << Journal;
Current Journal() << Save Journal("$TEMP/test2.jrn");
Open("$TEMP/test2.jrn");
If you print what you have in biv and journ, you will see that those are lists of references
biv = {Fit Group[], Fit Group[], Fit Group[], Fit Group[], Fit Group[], Fit Group[]};
journ = {Fit Group[], Fit Group[], Fit Group[], Fit Group[], Fit Group[], Fit Group[]};
Few options
	By(:Age)
Or
	By(:Age)
biv << Journal;
robot
Thanks Jarmo.
