AdamChoen
Run several dynamic user interface
I have several dynamic UIs that I launch through script buttons on my journal.
Each button simply runs an Include() of the relevant JSL file, for example:
Set Function(Include(
	"....\UIs\xxx_StationMonitor_Raw.jsl")
When I launch a second UI, the first one is no longer dynamic (its interactivity stops responding).
However, if I open both JSL files directly in JMP and run them manually, both remain fully dynamic and responsive.
It seems that running multiple includes from a journal somehow causes them to “override” each other’s state.
Is there a recommended way to launch multiple independent UI scripts from the same journal so that all remain active?
Thanks,
Adam
Thanks, Adam
Craige_Hales
Re: Run several dynamic user interface
I think the included JSL scripts are probably all sharing the journal's window context (which means they share JSL variables). Compare that to opening each script in its own window...each script has its own context from its JSL window.
If that sounds right, probably a small example (two scripts and a journal) will help someone suggest an answer that won't require a lot of re-work.
Craige
