tom_abramov
Level V
Run Stored procedure in SQL with JSL
I am trying to run a store procedure and get an error "Unknown error".
The command I use is
Execute SQL( MyConnection, "Exec spMyProcedure" );
The procedure doesn't return table, it just updates some table in SQL with data from another server.
While executing the procedure in SQL - no problems.
Any ideas? What is the best way to run stored procedures that are supposed to run several minutes and dont return any table?
Thank you.
Tom.
pmroz
Re: Run Stored procedure in SQL with JSL
If you're using Oracle this is how I get PL/SQL procedures to work:
Execute SQL( MyConnection, "begin spMyProcedure; end;" );
pmroz
mende001
How do you use this function for a SQL Server?
