voy-voy
Response Limits with if condition
Hallo Community,
I try to set column properties to draw always a line in my Charts. (Target Value)
But I use in my script the same Chart again for another Label.
So I try to skript 2 Response Limits but it doesn't work.
Is it possible to do it like this? Or is there any other Option?
Data Table( "Data1" ):"KM/MA"n <<
Eigenschaft festlegen(
	"Response Limits",
	If( :Firma_Job == "A", {Goal( Maximize ), Upper( 1138 ), Gewichtung( 1 ), Show Limits( 1 )},
			:Firma_Job == "J", {Goal( Maximize ), Upper( 230 ), Gewichtung( 1 ), Show Limits( 1 ) })
Re: Response Limits with if condition
The Column Property, Response Limits only allows for 1 set per column.  I suggest that you look into the possibility of splitting your data into multiple columns based upon  Firma_Job.  Then separate Response Limits can be set.  If that would not provide you an answer, then you may have to result to adding into your graph additional Reference Lines through the use of JSL.
