thentangler1
Resetting a zoom overriding scripts or levels
When i plot multiple plots with the same x-axis weere the graph is of 3rows x 1 column. And I zoom in one plot, and then zoom in another plot. and then change the plots type, say, from line to scatter and when i try to reset the zoom by double clicking it, it doesnt work.
I have to Start Over.
What is the method to reset the zoom to the original overriding the previous states or zoom levels?
Re: Resetting a zoom overriding scripts or levels
Double clicking seemed to work sometimes... but I had to double click on the different frameboxes and sometimes all of them did reset the zoom (but not always). You could also try right clicking on axis and using revert axis or revert scale.
Creating quick script / toolbar / add-in could also be an option
(Current Report() << XPath("//AxisBox")) << Revert Axis;
or
(Current Report() << XPath("//AxisBox")) << Revert Scale;
