PamAdi
Repeated measure
Good afternoon everyone,
My experimental design is the following: 4 cultivars on which we applied 3 treatments (with or without water and temperature stress). We sampled three times (t0days, t14days, t28dayso; on the same unit). Different parameters are analyzed. We want to compare the treatments to a control (no stress, t0) and the treatments between them. We also want to compare the times together (trend over time).
How can I do that with JMP?
Thanks,
PA
Re: Repeated measure
Go to the JMP pull down menu
     Help=>JMP Help,
and search for Repeated Measures.  It will bring up definition and an example of how to perform a Repeated Measures analysis in JMP.
