masum111bd
Renaming columns with loop
I am trying to rename few columns. Basically I want to append "OFL" character at the end of original column name.
I trried this script but no success.
For( i = 25, i <= N Cols( dt ), i++,
newname = :Column Name( dt, i )||"OFL";
Column( dt, i ) << Set Name( newname );
David_Burnham
Re: Renaming columns with loop
	cName = Column(dt,i) << Get Name;
	newname = cName|| "OFL";
-Dave
David_Burnham
-Dave
masum111bd
Thanks David. It works fine.
markschahl
Just in case you want to do this with a second data table, here's how:
How-to-rename-columns-using-a-second-data-table
I use this a lot now since #TXNelson showed me how to do this!
