saitcopuroglu
Renaming and/or saving data tables
I create a data table through tabulate and need to do further reports on that data table but each time it gives a name to data table "untitled XXX" (in this case untitled 14) . And since I need to automate the reporting and need to do it several times a day I need a "fixed name" for that data table  (and further save or not). How will I do it?
Thanks for your help
(Data Table( "AgencyStayISL.jmp" ) << Tabulate(
  Show Control Panel( 0 ),
  Uniform plot scale( 0 ),
  Add Table(
  Column Table(
  Analysis Columns(
  :RoomNight,
  :AdultNight,
  :PaidChildNight,
  :FreeChildNight,
  :BabyNight,
  :ArrivalRoom,
  :ArrivalAdult,
  :ArrivalFreeChild,
  :ArrivalPaidChild,
  :ArrivalBaby
  Statistics( Sum )
  Column Table( Analysis Columns( :ADR ), Statistics( Mean ) ),
  Column Table( Analysis Columns( :ADB ), Statistics( Mean ) ),
  Row Table( Grouping Columns( :Year, :Month, :day ) )
)) << Make Into Data Table
pmroz
Re: Renaming and/or saving data tables
A couple of recommendations:
1. Use a table variable instead of referring to a table by name.
2. Include the invisible keyword for the tabulation.  Less flashy-thingy effect
3. Use set name("new name") to change the name of the untitled table
Try the following code:
dt1 = Data Table( "AgencyStayISL" );
dtab = dt1 << Tabulate(
     Add Table(
           Column Table(
                Analysis Columns(
                     :RoomNight,
                     :AdultNight,
                     :PaidChildNight,
                     :FreeChildNight,
                     :BabyNight,
                     :ArrivalRoom,
                     :ArrivalAdult,
                     :ArrivalFreeChild,
                     :ArrivalPaidChild,
                     :ArrivalBaby
                Statistics( Sum )
     invisible
dt2 = dtab << Make Into Data Table;
dt2 << set name( "My Data Table Name" );
pmroz
     Add Table(
           Column Table(
                Analysis Columns(
                     :RoomNight,
                     :AdultNight,
                     :PaidChildNight,
                     :FreeChildNight,
                     :BabyNight,
                     :ArrivalRoom,
                     :ArrivalAdult,
                     :ArrivalFreeChild,
                     :ArrivalPaidChild,
                     :ArrivalBaby
                Statistics( Sum )
     invisible
Roselle_Grant
Thank you very much. This worked
