pmroz
Refresh Graph in Dialog Box
I'm displaying a radio box and a graph in a "new window".  If the user selects a different graph in the radio box I want the old graph deleted and the new graph displayed, all in the same window.  Not sure how exactly to do this.  Here's a simple example that displays the first chart.
dt = open("$sample_data\Big Class.jmp");
my_1_script = expr(
    my_gb = Graph Builder(
        Show Control Panel( 0 ),
        Variables( X( :weight ), Y( :height ) ),
        Elements( Points( X, Y, Legend( 1 ) ), Smoother( X, Y, Legend( 3 ) ) )
my_2_script = expr(
        Variables( X( :sex ), Y( :age ) ),
        Elements( Histogram( X, Y, Legend( 5 ) ) )
my_3_script = expr(
        Variables( X( :age ), Y( :age ) ),
        Elements(
            Pie( X, Y, Legend( 2 ), Pie Style( "Pie" ),
                Summary Statistic( "Mean" ), Label( "No Labels" )
chart_list = {"Chart 1", "Chart 2", "Chart 3"};
my_win = new window("Chart Display",
    panelbox("Graph Options",
        hlistbox(
            panelbox("Select Chart",
                chart_rb = radiobox(chart_list,
                    selected_chart = chart_rb << get selected;
                    if (selected_chart == "Chart 1",
                        my_1_script,
                        selected_chart == "Chart 2",
                        my_2_script,
                        selected_chart == "Chart 3",
                        my_3_script
// Default is chart 1
    my_1_script
ms
Super User (Alumni) ms
Re: Refresh Graph in Dialog Box
If given a variable name, the graph can easily be deleted before appending the graph to the window.
This seems to work:
my_win = New Window( "Chart Display",
      Panel Box( "Graph Options",
            H List Box(
                  Panel Box( "Select Chart",
                        chart_rb = Radio Box(
                              chart_list,
                              If(selected_chart == "Chart 1",
                                          gb << delete;
                                          my_win << append( gb = my_1_script ),
                                          gb << delete;
                                          my_win << append( gb = my_2_script ),
                                          gb << delete;
                                          my_win << append( gb = my_3_script ),
      gb = my_1_script
ms
This seems to work:
            H List Box(
                              chart_list,
                                          gb << delete;
                                          gb << delete;
                                          gb << delete;
      gb = my_1_script
pmroz
Truly awesome MS.  I knew it was relatively simple but couldn't quite get the syntax right.  Thanks!
ms
This is a simpler version using the same approach that may be easier to generalize:
script_list = {my_1_script, my_2_script, my_3_script};
            H List Box(
                              chart_list,
                              gb << delete;
                              my_win << append( gb = Eval( script_list[chart_rb << get] ) )
      gb = eval(script_list[1])
