Satya1
Recode column names
I am very new to JMP and would like to know how to rename the existing column name if it contains some character string that I am looking for ?
For example if original column name is "ghdl_Male_test_case", how do I rename it to just "Male" ? Thanks in advance.
Re: Recode column names
There is a Column Recode dialog
     Cols=>Column Names=>Recode Column Names
Or you can use a variation on the below script to do the recoding
dt = Current Data Table();
colNamesList = dt << get column names( string );
For Each( {col, i}, colNamesList,
	If( Contains( col, "Male" ),
		Column( dt, col ) << set name( "Male" )
Satya1
I forgot to mention that I am looking to rename multiple columns using JSL script.
Satya1
Thank you so much Jim :)
