djrisks
Read-only JMP table
Hey,
Does anyone know how to make a JMP data read-only? I would like to make sure that the data in the JMP table cannot be modified. I've seen that there is a Lock Data Table option, but that can easily be unlocked so I am interested in another solution please.
Many thanks in advance.
Kriss
Jeff_Perkinson
Read-only JMP table
Hi Kriss,
At the operating system level you can set the file to be read-only, but there's no option in JMP other than the Lock Data Table choice from the red triangle menu in the data table.
-Jeff
-Jeff
djrisks
Read-only JMP table
Hi Jeff,
Thank you for the confirmation!
-Kriss
