smithwoosley
Radio Box to Text
How can I turn a selection from a radio box into text?  Trying below with no luck.  Or is there some other simpler solution?
win = New Window( "Radio Box",
	<<Modal,
	<<ReturnResult,
	Panel Box( "Select",
		rbox = Radio Box( {"A-CMP-1", "A-CMP-2"} ),
		toolcode = rbox<<get text;
DSNString= "Driver={SQL Server}; SERVER=rb; DATABASE=FAB; UID=fab; ";
sqlStr=
select vcLotCode, vcToolCode
from EDB.dbo.tFABDATA
where vcLotCode like 'Lot.1234'
and vcToolCode like '"|toolcode|"'
dt = Eval(Substitute(Expr(dt=Open Database(DataSource,sqlcode,"Lots");),Expr(sqlcode),sqlstr,Expr(DataSource),DSNString));
Re: Radio Box to Text
I believe your issue is your concatenation operators.  In JSL a concatenation operator is  ||, not | as in your example
toolcode="zippy";
sqlStr=
and vcToolCode like '"||toolcode||"'
smithwoosley
Ah, that was one problem.
Also had to use "get selected" instead of "get text".  Also had to move "get selected" outside of the new window parenthesis.
Works now.  Thanks!
toolcode="zippy";
sqlStr=
smithwoosley
Works now.  Thanks!
pmroz
You don't have to do as much manipulation for the call to the database.  Also evalinsert makes the sql a little cleaner.
	<<Modal,
	<<ReturnResult,
		toolcode = rbox << get selected;
sqlStr = evalinsert(
"select vcLotCode, vcToolCode
    and vcToolCode like '^toolcode^'");
dt = open database(dsnstring, sqlstr, "Lots");
