Jaz
Jaz
Level V
RE: Importing a CSV File Into JMP & Turning it Into a Data Table
This must be a very simple question but there is a lack of documentation so I was struggling with how to import CSV files into JMP and save them as data tables?
Any help would be appreciated.
Jeff_Perkinson
The Import Text Files section of Using JMP explains how to use File->Open to import text files, including .CSV files.
-Jeff
Jeff_Perkinson
-Jeff
Jaz
Jaz
Level V
Thanks, much appreciated.
.csv files are opened directly in JMP.  They are treated as just another file to open.  So if you are running interactively, you just go to
     File==>Open
and then navigate to the .csv file you want to open, and then open it
To save it as a JMP file, just go to
     File==>Save As
In JSL the following is the code:
dt = Open( "<path and file name.csv>" );
close( dt, save( "<path and file name.jmp> " ) );
Documentation for the interactive open and save is in
     Help==>Books==>Using JMP
Documentation for the JSL is in
     Help==>Scripting Index
or
     Help==>Books==>Scripting Guide
AY
AY
Been scrolling for hours to find this kind of solution. Thanks @txnelson !
AY
AY
