blip555555
R^2 value standard least square with random effects
Good afternoon,
I was wondering when fitting a mixed model using standard least squares and adding random effects as attributes, is the R-squared reported an R-squared accounting for fixed and random effects?
Thank you!
statman
Re: R^2 value standard least square with random effects
R-square is the amount of the total variation in the study explained by the model.
MRB3855
Hi @blip555555 : To see what JMP reports in this situation, run the model twice; once with the factors' attributes set to random, and once leaving the factors as fixed effects. You will then know the answer to your question; if the R^2 are the same, "yes". Otherwise, "no".
