hongyu1
Question about R2 for weighted linear regression in JMP
I used JMP to conduct a weighted linear regression analysis. However, RSquare value of the regression output by JMP (around 0.76) doesn't match my own calculation using the general formula of R2 = 1 - SS_residual/SS_total (around 0.78).
The regression parameters output by JMP match my own calculation, so I suppose the regression was conducted correctly. I was wondering if R2 output by JMP is incorrect, or JMP is using a different formula other than the general formula to calculate R2.
https://en.wikipedia.org/wiki/Coefficient_of_determination
Attached is the input data I used for this analysis.
Victor_G
Re: Question about R2 for weighted linear regression in JMP
Hi @hongyu1,
You can check the formula used by JMP for the calculation of R² in this section : Summary of Fit
However, using this formula or the one you mentioned leads to identical results, as SS(total) = SS(model) + SS(error).
If I use your formula with the informations provided by JMP, I find the same R² value :
1 - (SS(error) / SS(total)) = 1 - (1174,3486 / 4971,1282) = 1 - 0,23623382 = 0,763766 (as displayed by JMP on your screenshot).
Maybe the difference could be caused by a rounding in the calculation ?
Hope this answer will help you,
Victor GUILLER
