Emily_Day
Question Regarding "contains()" formula
I have a set of CATA data where the nominal data looks like column "Data" below.  I'm attempting to create an additional column for each selection (like "Answer 1, Answer 2, etc. below) where "0" = not found in the list and "1"= found.
Here is my formula:                       Contains( :Name( "Data" ), "1" ) > 0
However, it is picking up the number 1 from an 11 and is returning a "1" response for Answer 1 when it should be "0".
Maybe I've gone about this all wrong and there is a better way to accomplish this task?  Any suggestions?
Data
Answer 1Answer 2Answer 3
1,2,3,6,11111
2,5,6,11010
3,11,12,13001
Byron_JMP
Re: Question Regarding "contains()" formula
This might help
select your "Data" column
Cols>Utilities>Text into columns
then use "," as the delimiter and check the, Make Indicator columns.
Byron_JMP
This might help
Emily_Day
Beautiful!  That is exactly what I needed and way easier than my round-about method.
Much appreciated!
G_M
G_M
@Emily_DayI am not sure I understand your logic completely, but perhaps the following will help.
Names Default to Here(1);
dt = New Table( "Sample",
	Add Rows( 3 ),
	New Column( "Data",
		Character,
		"Nominal",
		Set Values( {"1,2,3,6,11", "2,5,6,11", "3,11,12,13"} )
dt << Text To Columns(
	delimiter( "," ),
	columns( :Data )
dtStacked = dt << Stack(
	columns( :Data 1, :Data 2, :Data 3, :Data 4, :Data 5 ),
	Source Label Column( "Label" ),
	Stacked Data Column( "Response" ),
	Output Table Name("StackedData")
dtStacked:Response<<Data Type("Numeric");
dtStacked << New Column(
	"Answer",
	Numeric,
	Nominal,
	Formula(
		"Insert your Logic Here"
dtWide = dtStacked << Split(
	Split By( :Label ),
	Split( :Answer ),
	Group( :Data ),
	Remaining Columns( Drop All ),
	Sort by Column Property,
	Ouput Table Name("WideData")
