Françoise
Query Builder with Excel file with Excel Filter
hi,
i use a query builder to import an excel file. but if someone put a filter in the excel file, the query import less lines.
how to make a query builder which import all the lines even the hideen lines in excel?
best regards
Re: Query Builder with Excel file with Excel Filter
I just ran a simple test to verify, but query builder brings in all of the rows for me even from a filtered Excel spreadsheet.
Now if I OPEN an Excel table, the default behavior is that I only receive the filtered Excel rows. To fix this problem, in the Excel Import Wizard, click the NEXT button at the bottom of the page. Clear the checkboxes that suppress the hidden rows/columns.
Dan Obermiller
Dan Obermiller
Françoise
ok,
It's good.
thanks
Françoise
hi,
 I'm using 4 filters for the same query builder to select lines.
another pb: all the lines are selected. Last week, it was OK.
explications?
best regards
Françoise
I use a filter which has 2 values selected.
It' OK.
when I add an another filter (on an another variable) with 2 values selected:all the lines are selected as the query builder don't use the filters.
best regards
Could you possibly share an example of what you are trying to do?? It is too difficult to determine what is going wrong without that example. Thanks.
Dan Obermiller
