aatw
Python integration get column properties
Is there a way to get column properties from JMP data table (such as "Design role" and "Factor changes") in python, if I use df = jmp.current() as a reference to the opened JMP data table?
I am aware of df[0].dtype and df[0].mtype to get data type and modeling type properties, but I would like to list the factors and responses in python from a DoE generated table.
Thanks!
Re: Python integration get column properties
You get None because you don't have access to here namespace. You can use Python Send
import jmp
jmp.open(jmp.SAMPLE_DATA + 'Big Class.jmp')
df = jmp.current()
jmp.run_jsl('''
dt = Python Get(df);
cname = dt << Get Column Names("string");
Python Send(cname);
print(cname) # ['name', 'age', 'sex', 'height', 'weight']
12 REPLIES 12
You can always fallback to run_jsl if some feature hasn't yet been implemented
aatw
Sure, however the following code:
df = jmp.current()
sc = jmp.run_jsl('df << Get Column Names();')
print(sc)
returns the following error: Name Unresolved: df in access or evaluation of 'df' , df/*###*/
Any ideas?
JMP side doesn't know about your df python variables unless you "share" them. No idea what is preferred method, but you can for example use jmp.here
import jmp
dt = jmp.open(jmp.SAMPLE_DATA + 'Big Class.jmp')
jmp.here["dt"] = dt
jmp.run_jsl('''
	p = Column(dt, "name") << Get Property("Notes");
print(jmp.here.get('p'))
Or you could use Python Get from JMP side of things
import jmp
jmp.run_jsl('''
	dtref = Python Get(dt);
	p1 = Column(dtref, "name") << Get Property("Notes");
print(jmp.here.get('p1'))
aatw
Very useful, thanks. Although when running:
df = jmp.current()
jmp.run_jsl('''
dt = Python Get( df );
cname = dt << Get Column Names();
print(jmp.here.get('cname'))
I get "None" as output, despite obviously having some columns in my table.
Also, if using the script with "Names Default To Here(1)", my JMP crashes...
import jmp
df = jmp.current()
jmp.run_jsl('''
Python Send(cname);
aatw
Many thanks jthi!
This works, not only due to using Python Send (because I tried that before), but also due to specifying "string" type for cname.
aatw
Another question/wish: how would one scroll through all columns and check whether they have a "Design Role" or "Factor Changes" property, and list only those columns?
Do you want the result in Python list if one of those properties is found for the columns?
aatw
Yes
