BHKReddy
Python Access Issue while installing Packages
Hello JMP Community,
Recently started using JMP and tried to access the Python and while installing the python packages, I am getting error like below.
Any support in resolving the below error is much appreciated. Refer below image along with code used and error.
Thank you
10 REPLIES 10
Re: Python Access Issue while installing Packages
Try installing the package via Windows Command Line using trusted-host.
"C:\Program Files\JMP\<JMPPRO|JMP>\<version#>\jmp_python.exe" -m pip install --trusted-host=pypi.org --trusted-host=files.pythonhosted.org --user <module name>
E.G., installing numpy within JMP Pro. "C:\Program Files\JMP\JMPPRO\18\jmp_python.exe" -m pip install --trusted-host=pypi.org --trusted-host=files.pythonhosted.org --user numpy
Caution: note that this is insecure and can lead to other issues. The error occurs when attempting to access a package repository behind corporate firewalls. Please evaluate with your IT department before considering this as a solution.
Dahlia Watkins
