senatorx
Proper syntax to color cells where column name has a space
Hi, I found in the forums that you can color table cells by sending the color cells(...) command to a table column.
It works fine when sending to a column with no spaces in the column name, such as ":Roast", however a column title with a space fails.  What is the proper syntax for column names with spaces?
Thanks.
coffee_dt = New Table();
coffee_dt << New Column("Coffee Name", Character, Nominal);
coffee_dt << New Column("Roast", Character, Nominal);
coffee_dt << AddRows(2);
Column("Coffee Name")[1] = "Veranda";
Column("Coffee Name")[2] = "Pike Place";
Column("Roast")[1] = "Medium";
Column("Roast")[2] = "Dark";
:Roast << color cells("red", coffee_dt << get rows where(:Roast=="Medium"));
Column("Coffee Name") << color cells("green", coffee_dt << get rows where(Column("Coffee Name")=="Pike Place"));
pmroz
Re: Proper syntax to color cells where column name has a space
This syntax works:
:Coffee Name << color cells("green", coffee_dt << get rows where(:Coffee Name == "Pike Place"));
It doesn't like column("Coffee Name") in the where clause for some reason.  If you have strange characters in the column name you can use the :name() construct.  This works:
Column(coffee_dt, "Coffee Name") << color cells("green", coffee_dt << get rows where(:name("Coffee Name")=="Pike Place"));
pmroz
This syntax works:
