bgeaibreyi
Process Capability Spec Limit Setting
I have the attached JMP sheet that I'm trying to run process capability analysis for. The process has different specification limits for each "condition" but when I run the analysis it only allowed me to set one set of limits. Is there any way to set different limit for different conditions? Or I will have to break into multiple columns as "Performance@20", "Performance@40", etc..?
Thanks,
Gary
11 REPLIES 11
bgeaibreyi
Re: Process Capability Spec Limit Setting
I have a follow up question regarding the process screening example "Semiconductor Capability" tutorial file. When we launch process screening it doesn't ask to specify LSL and USL and it doesn't look like it's contained anywhere in the table. How does the screening report generate with specifications?
Thanks,
Gary
bgeaibreyi
This clarifies things and gives me what I need! Thanks much.
