martaruth0
Problem using Graph Builder with Data Filter
Graph Builder works succussfully with the Data Filter adjusteing the plotted points properly when the Data Filter slider is moved. Also, the values of the statistics using the Caption Box adjust with the Data Filter slider as expected. So far, so good. Then I wanted to plot the mean of a column using 'Customize' and 'Y Function'. The following is the extracted script:
Add Graphics Script(
  3,
  Description( "Script" ),
  Y Function( Col Mean( :_columnexample_ ), x )
The desired mean line is plotted successsfully. However, the plotted line is unresponsive to the Data Filter slider.
How can I plot the column mean that works with the Data Filter?
Re: Problem using Graph Builder with Data Filter
The solution will probably be dependent upon whether you are using a Data Filter, or a Local Data Filter.  If you are using a Data Filter, you can apply a Row State Handler to the data table, that will redraw the Y Function.  If it is a Local Data Filter, the key will be in finding what is changed in the graph by the filter that one can trigger on, to redraw the Y Function.
If you can provide more details on the Data Filter you are using, I might be able to provide more of a solution
martaruth0
Thanks for the response.
Here's the script for the data filter, it's not local:
Current Data Table() << Data Filter(
Location( {325, 212} ),
Mode( Show( 1 ), Include( 1 ) ),
Add Filter( columns( :Bandmeter ), Where( :Bandmeter >= -100 & :Bandmeter <= -50 ) )
I'm guessing the problem lies with the Include(1) statement, perhaps it should be Exclude. My 30 day free trial just ended, so I'll have to wait to get a license to test it.
Some arbitrary initial values for the filter are included simply because I haven't figured out yet how to include all the rows of the current data table. It seemed to be a lesser issue at the moment, but I'm also presuming that it is not the cause for the difficulty in the use of the Data Filter with the Y Function.
ian_jmp
Level X
Building on Jim's thought, here's one way (with the local data filter):
NamesDefaultToHere(1);
// Graph Builder
gb = dt << Graph Builder(
Lock Scales( 1 ),
Variables( X( :weight ), Y( :height ) ),
Elements( Points( X, Y, Legend( 6 ) ), Line Of Fit( X, Y, Legend( 8 ) ) ),
// Get a reference to the report
gbReport = gb << Report;
// Add a local data filter
ldf = gb << Local Data Filter( Add Filter( columns( :sex ) ) );
// Row state handler function that adds a horizontal line to Graph Builder at the mean of the current
// selection in the local data filter
addMeanYLine =
Function({x}, {Default Local},
// Get rows corresponding to the current selection
rows = ldf << getFilteredRows;
// Get the required mean value
mv = Mean((Column(dt, "height") << getValues)[rows]);
// Add the graphics script to the Graph Builder display box . . .
gFrames = gbReport << XPath( "//FrameBox" );
// Try to remove a graphics script that might already be there
Try(Send(gFrames[1], RemoveGraphicsScript(1)));
// Expression that will add the required graphics script
ags = Expr(Send(gFrames[1], AddGraphicsScript(PenColor("Red"); HLine(TBD))));
// 'Bake in' current mean value
SubstituteInto(ags, Expr(TBD), mv);
ags;
// Assign the row state handler to the local data filter display box
rsh = gbReport[OutlineBox(1)] << MakeRowStateHandler(addMeanYLine);
martaruth0
Thank you Ian for answering. I have studied your script and see that it works. In my case, however, I need to keep the data filter global so that many graphs can be affected at once, and I haven't yet managed this.
