frankderuyck
Problem to find optimal settings for a mixture with Bayesian Optimisation
With a 24 run mixture DOE I could find very good models and optimal settings for a ternary mixture and one categorical effect, this was presented in foregoing discussion; find in attachment again the analysis and below screenshots of the desirability results.
With Isomer 2 desirability result is worse; below the settings when locking Isomer 2
Starting with a 9 run candidate space filling set (see attachment Succesful 9 run) set or a 12 run Kowalski set the optimal settings with Isomer 1 can be detected.
However starting from a 6 run space filling candidate set I always get the poorer optimal settings with Isomer 2, even after several added space filling runs! What did I do wrong and how to get from this 6 run candidate the optimal Isomer 1 settings?
14 REPLIES 14
frankderuyck
Re: Problem to find optimal settings for a mixture with Bayesian Optimisation
No succes after double Max Multimodel Std Dev, low desirability at Isomer 1 and BO goes back to Isomer 2
Victor_G
Frank, please start ONLY with your 6 initial space filling runs, without any BO scripts in the table (remove the scripts and delete any other rows).
Then, launch the BayesOpt platform with default settings, remove any automatic batch recommendation and add 1 Max Multimodel Std Dev for 2 iterations, and you should be able to get results close to your optimum with isomer 1 (and matching my testings). As soon as the two consecutive Max Multimodel Std Dev runs have been added, you should see a correct ordering of the isomer types :
Victor GUILLER
frankderuyck
Hi Victor, I followed your instructions cfr. attachment and I can't replicate your resuts? The models built with the 6 initial space filling rus are poor so I don't understand why to sart here with Max Multimodel st deviation: the outcomes are not learning a lot from poor Gaussian Process models?
frankderuyck
In your result you have only 2 outputs; there must be three
frankderuyck
And after only 6 initial space filling runs Gaussian Y1 is very poor so additional space filling runs are required to get acceptable model performance;  unfortunately, each time again, BO detects isomer 2 as optimal (?)
