marks
Power Fit Equation for JMP
I have data that follow a power law and I need to plot the regression and use the coefficients for lifetime calculations.  Is there a method, or script, developed to do this in JMP?
peterj
Re: Power Fit Equation for JMP
You can create a power model using the Analyze -> Modeling -> Non-linear. In the model library, select Model E (2P) to create the new formula for your prediction.
Attached is a script that creates some random data and will create a power fit through the data. In this example z=x^y and the fit is done accordingly.
peterj
