rinosaur
Paste data from JMP to Excel
I currently have a script which automatically populates a JMP table with Excel data, then runs a non-linear regression and saves the fitted data. I would then like to copy these new columns back into the same, open, Excel document. Is there a simple way to select the new columns, and then copy the data to the clipboard using JSL so I can paste it back in Excel?
Cheers,
David_Burnham
Re: Paste data from JMP to Excel
You need to scan the table and build up a text string that you can put into the clipboard using the Set Clipboard function.
Use the tab escape (\!t) sequence to separate columns and the new line escape sequence (\!N)to create rows
Set Clipboard( "col 1 row 1\!tcol 2 row 1\!tcol 3 row 1\!Ncol 1 row 2\!tcol 2 row 2\!tcol 3 row 2" );
-Dave
uday_guntupalli
Level VIII
@rinosaur ,
     Hello. The following piece of code might be useful in achieveing what you are after :
// Open Sample Data
// Specify Output Folder Location - edit per your needs
OutputFolder = "C:\";
// Get List of Columns
ColNames = dt << Get Column Names("String");
// Specify Columns you desired to copy and paste into excel
DesColumnsList = {"age","sex"};
// Loop through columns to select columns you want
for(i = 1, i <= N Cols(dt), i++,
		If(Contains(DesColumnsList,ColNames[i]),
				Col = Column(dt,i); // Get Reference for Column
				Col << Set Selected(1);
// Subset Selected columns
dt_New = dt << Subset(Selected Rows(0),Selected Columns(1));
// Save Desired Table
Close(dt_New,Save(OutputFolder || "test.xlsx"));
Best
Uday
rinosaur
Hi @uday_guntupalli
This is similar to what I was thinking, making the subset and copying from there. But this would make a new workbook, correct? I am looking to copy the subset to the clipboard and then later on paste into the original workbook if possible.
uday_guntupalli
Level VIII
@rinosaur
How about this ?
// Opem Sample Data
// Write to Excel
Create Excel Workbook("C:\Test.xlsx",{"Big Class"},{"Big"});
// Open Another Sample Data Set
dt1 =  Open( "$SAMPLE_DATA/Air Traffic.jmp" );
// Write both tables to existing workbook
Create Excel Workbook("C:\Test.xlsx",{"Big Class","Air Traffic"},{"Big","Air"});
However, in your case , you will directly append the data into a new tab in Excel to your workbook using the last step .
So - open you excel workbook as a JMP data table , then have a second data table with the data you want to write and then use Create Excel Workbook as shown above to write to Excel.
If you want all the data in the same tab , just join the JMP data tables and write to Excel . Hope this helps .
Best
Uday
David_Burnham
-Dave
