Neo
Neo
Passing column name as argument to a function - is concatenating with : needed?
Below is a function where I am trying to pass a column name for plotting a distribution, but it is not working. I am wondering what is the correct syntax?
Names Default To Here (1);
getDistChart = Function({ColName}, {dC},
dC = Distribution( Continuous Distribution( Column( :ColName) ) );
return(dC);
//gt = getDistChart ("MyCol"); to test the function
I have already got the data table with MyCol as a column name open. I am wondering if I need to concatenate
 with the column name
ColName
If so how (as normal concatenation with || || does not seem to be working)?
When it's too good to be true, it's neither
Re: Passing column name as argument to a function - is concatenating with : needed?
Yes, it works perfectly for me with JMP Pro 16.1.0. I do not have any earlier versions of JMP installed to test. Your version is about 5 years old. JSL is constantly evolving, so it is possible that my syntax does not work for an earlier version.
You might contact JMP Technical Support ([email protected]) for help.
You might also try using expressions to accomplish what you want. They work for any version of JMP, since version 4. See if this version works:
getDistChart = Function( {ColName, _LSL, _USL}, {distChart},
	Eval(
		Substitute(
			Expr(
				distChart = New Window( "" || ColName || " distribution",
					Distribution(
						Stack( 1 ),
							Column( As Column( ColName ) ),
							Horizontal Layout( 1 ),
							Vertical( 0 ),
							Capability Analysis( LSL( _LSL ), USL( _USL ) )
							Dispatch(
								{ ccc },
								"Distrib Histogram",
								FrameBox,
								{DispatchSeg( LabelSeg( 1 ), {Font( "Segoe UI", 7, "Plain" )} ),
								DispatchSeg( LabelSeg( 2 ), {Font( "Segoe UI", 7, "Plain" )} )}
			Expr( ccc ), colName
	Return( distChart );
getDistChart( "weight", 55, 185 );
6 REPLIES 6
getDistChart = Function( {ColName}, {dC},
	dC = Distribution( Continuous Distribution( Column( As Column( colName ) ) ) );
	Return( dC );
gt = getDistChart ("weight");
Neo
Neo
@Mark_Bailey Thanks it works. However, I am getting stuck advancing to the next step. I would like to pass the column name to several places in my script. Using Big Class as an example below. I am able to pass the ColName to New Window but not to Dispatch
getDistChart = Function({ColName, _LSL, _USL}, {distChart},
New Window(""||ColName||" distribution",
Distribution(
	Stack( 1 ),
		Column(As Column (ColName) ),
		Vertical( 0 ),
		Capability Analysis( LSL(_LSL ), USL(_USL) )
		Dispatch(
			{"weight"},
			FrameBox,
return(distChart);
getDistChart ("weight", 55, 185);
For example this
Dispatch(	{ColName},...
or this from here
Dispatch(	{Expr(ColName)},...
does not work. What is the correct syntax to pass a string as argument for Dispatch?
	{distChart},
		Distribution(
			Stack( 1 ),
				Vertical( 0 ),
				Dispatch(
					{colName},
					FrameBox,
Neo
Neo
@Mark_Bailey  Thanks. Running your script gives me the following in the log
Cannot find item "ColName" in outline context {ColName}
Does it work for you?
(I am on JMP 13)
	Eval(
		Substitute(
			Expr(
					Distribution(
						Stack( 1 ),
							Vertical( 0 ),
							Dispatch(
								{ ccc },
								FrameBox,
Neo
Neo
Thanks @Mark_Bailey  This works.
