adam
Pass and Fail Condition
Hi Guys,
I have the following table and would like to know how shall I set the formula(or JSL) where in this case, based on ID and MAIN_RAD, I would like to check on the value of SUB_1 to SUB_3. The condition is if at least 2 of the SUB has a value of more than 20 then it will be considered as FAIL otherwise PASS.
For instance as you will notice, for M101X at MAIN_RAD 1, the SUB_3 is more than 20 but consider PASS as it did not fulfill the condition of at least 2 SUB more than 20 in spec limit.
Thank you.
IDMAIN_RADSUB_1SUB_2SUB_3RESULT
M101X1101529PASS
M101X215516PASS
M102W1251830FAIL
M102W281411PASS
M110A1321215PASS
M110A2514530FAIL
Re: Pass and Fail Condition
Here is a formula that will do what you want
If( Sum( SUB_1 > 20, SUB_2 > 20, SUB_3 > 20 ) >= 2,
	"Fail",
	"Pass"
The Sum() function is documented in the Scripting Index
     Help==>Scripting Index==>Functions==>Sum
The handling of Boolean logic is covered in the Scripting Guide
     Help==>Books==>Scripting Guide
If you are going to to be using JSl, you need to take the time to read the Scripting Guide!
	"Fail",
	"Pass"
adam
Thanks Jim !
