JMP__learner
Paired Test with Nominal Data
Can someone advice how to find a test to compare  paired nominal data in JMP, please?
I have data looking at use of a drug (Yes/No) to be compared before vs after hospital admission (Before/After).
Previous post asking a similar question suggested to use "Agreement Statistics" on Contingency Analysis. However, I cannot find this option with my JMP (Pro 16).
Any help is appreciated.
statman
Re: Paired Test with Nominal Data
Welcome to the community.  A quick look at JMP help brings up the following:
https://www.jmp.com/support/help/en/16.2/?os=mac&source=application&utm_source=helpmenu&utm_medium=a...
statman
JMP__learner
Thank you for the response and the link. I think the issue was the organization of the dataset, and now the option appeared with the contingency analyses as described on the link page :)
