ebluhm
Overlay markers on multiple graphs
These are the graphs that I'm working in. I'm new to JMP and I've been trying to figure out how to make all three of these graphs have the same attributes that the bottom one has from the legend. I need all three graphs to use the same overlay markers and colors. Any help would be appreciated!
Re: Overlay markers on multiple graphs
Which version of JMP aer you using? Have you tried Graph Builder? What does you data table look like?
If you are using JMP 13 you can use a column as a Paging variable (lower right zone) which will keep all the colors and markers the same. You can also use Overlay and Color zones in the upper right. 2 y-axis are allowed with multitple varaibles in each.
The more information we have, the easier it will be for us to help.
Chris
Chris Kirchberg, M.S.2
www.jmp.com
