Neo
Neo
Output data table together with error message from a function (JMP13)
My JSL function script below pulls a file from a network folder and outputs it in a data file for use elsewhere. How do I output the error message "This limit file does not exist! Check file name" together with the datafile. I am on JMP13.
getLimitsFile = Function({LimFileName}, {dtspk},
dtspk = Try(
Open(
	"\\gbshyt-ppor-334e\DBX\XPD\System\Limits\"||LimFileName||".txt",
	columns(
		New Column( "ParameterName", Character, "Nominal" ),
		New Column( "ColumnLSL", Character, "Nominal" ),
		New Column( "ColumnUSL", Character, "Nominal" ),
		New Column( "ColumnUnits", Character, "Nominal" ),
		New Column( "ColumnSymb", Character, "Nominal" ),
		New Column( "ColumnComm", Character, "Nominal" )
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Tab, Comma, CSV( 1 ) ),
		Strip Quotes( 1 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		CompressNumericColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 1 ),
		Column Names Start( 1 ),
		Data Starts( 2 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
//,invisible)
),"This limit file does not exist! Check file name");
return(dtspk);
Also, in the case of an error, how to stop further execution of the code where the function is used and show the user a dialog box with the error message?
When it's too good to be true, it's neither
Re: Output data table together with error message from a function (JMP13)
In that case use Return() instead of Throw()
8 REPLIES 8
If JMP13 provides File Exists() function you could use it with if statement. Then it is a decision what to return / how to stop program. You can use for example Throw() or Stop()
	If(!File Exists("\\gbshyt-ppor-334e\DBX\XPD\System\Limits\"||LimFileName||".txt"),
		Throw("This limit file does not exist! Check file name");
		//or use return and throw outside function
	//Open...
	return(dtspk);
getLimitsFile("");
Show("continue...");
Edit:
Which datatable would you like to return with the error? If you cannot open the file, there is no datatable to return unless you create empty one.
Neo
Neo
Thanks @jthi, Yes, JMP 13 does have File Exists (). I will try it.
I did not phrase my query correctly earlier. When the file does not exist, I just want the function to just output the error in a dialog box and stop further execution.
When the file exists, I only want the data table only and message output. How to achieve this?
Do you have a dialog box outside the function which you want to fill with the message of error? And with datatable you want to return message output with the datatable?
Neo
Neo
I do not yet a dialog box on the main code which uses the function.
When there is an error due to user passing an incorrect file name, I want the main code to show the user a dialog box with the error and stop any further execution of the main code. When there is no error in the file name, the file is pulled from the network location and passed into a data table which needs to be available in the main code. Hope I have answered your questions @jthi
Sure, those should be enough! This will be a bit application dependent (and programmer/scripter) how you want to handle the error.
The example below has two fairly simple options how you could handle this. If JMP13 behaves similarly to JMP16 these both should be fine (of course it depends also on your application). The difference is that first one will throw an error inside the function, second one will return string if there is problem with the file path and the result is handled outside the function.
open_file_with_throw = function({file_path}, {default local},
	If(!File Exists(file_path), //! inverts the File Exists result
		Throw(Eval Insert("^file_path^ file doesn't exist, check file path"));
	dt = Open(file_path);
	return(dt); //return datatable reference
open_file_with_throw("testpath");
Show("Shouldn't be executed, due to throw");
//with working file path you will get reference to opened table returned
dt = open_file_with_throw("$SAMPLE_DATA/Big Class.jmp");
open_file_with_return = function({file_path}, {default local},
		return(Eval Insert("^file_path^ file doesn't exist, check file path"));
// this wont error, so you will have to handle error yourself
// one thing I don't like about this solution, is that you will have two different types of returns
// from same function
result = open_file_with_return("testpath");
If(Type(result) == "String",
	//Throw(result);
	//or you can build the error with modal window and stop after it is closed
	//@craige_hales post has quite good template for this type of modals here: https://community.jmp.com/t5/Uncharted/Modal-Dialogs/ba-p/436177
	//below is very simple one
	New window("Error", << modal,
		text box(result)
	stop();
Show("Shouldn't be executed, due to stop");
Neo
Neo
Thanks @jthi. How to catch the throw message in a dialog box? Below does not seem to work.
result = open_file_with_throw("testpath");
Show(result);
		text box(result)
	stop();
Craige_Hales
I prefer the throw because it can be caught if needed, and stops the JSL if it isn't caught.
open_file_with_throw = Function( {file_path},
	{default local},
	If( !File Exists( file_path ), //! inverts the File Exists result
		Throw( Eval Insert( "^file_path^ file doesn't exist, check file path" ) )
	dt = Open( file_path );
	Return( dt ); //return datatable reference
moreJSL = Function( {dt},
	Show( N Rows( dt ) );
	Close( dt, nosave );
errorHandler = Function( {msg}, Show( msg ) );
Write( "\!ncase 1:" );
Try(
	dt = open_file_with_throw( "$sample_data/big class.jmp" ),
	dt = Empty();
	errorHandler( exception_msg );
If( !Is Empty( dt ),
	moreJSL( dt )
Write( "\!ncase 2:" );
Try(
	dt = open_file_with_throw( "testpath" ),
	dt = Empty();
	moreJSL( dt )
// or even this, but the error handler may be handling exceptions from moreJSL() as well as open_file_with_throw()
Write( "\!ncase 3:" );
Try( moreJSL( open_file_with_throw( "$sample_data/big class.jmp" ) ), errorHandler( exception_msg ) );
Write( "\!ncase 4:" );
Try( moreJSL( open_file_with_throw( "testpath" ) ), errorHandler( exception_msg ) );
Craige
