Jackie_
Open() , save and close while script is running
Is there a way I could open the data table, save in the variable and close it while the script is running? It's annoying sometimes because the input data table will pop up. I tried using close window, close() but they didn't seem to work.
Clear Globals();
Clear Log();
dt2 = Current Data Table();
nw = New Window( "New window",
			<<modal(),
			Text Box(
				"Tests",
				<<Set Font Style( "Bold" ),
				<<Set Wrap( 1000 )
			Spacer Box( Size( 20, 20 ) ),
			H List Box(
				Panel Box( "Input JMP file",
					<<set font style( "Bold" ),
					Button Box( "Select file", dt1 = Open(), <<setIcon( "ListItemAdd" ) ) // Can I use close window syntax? here
				Spacer Box( Size( 20, 10 ) ),
			Panel Box( "Actions",
				H List Box(
					align( center ),
					Button Box( "OK",
						keep_going = 1;
						todo_list = my_cb << get selected, <<setIcon( "CheckCircle" );
					Button Box( "Cancel", keep_going = 0, <<setIcon( "ErrorSmall" ))
			<<Size Window( 340, 430 )
Re: Open() , save and close while script is running
Could hiding the window work (make it invisible). Then if you need to make it visible you can use << Show Window(1);.
Here is how to set invisible directly in Open function, but I think this requires you to have the path
dt = Open("$SAMPLE_DATA/Big Class.jmp", invisible);
wait(2);
dt << Show Window(1);
In your case you might have to first let the table open as visible and then use << Show Window(0); to hide it
dt = Open();
dt << Show Window(0);
Even better might be using file_path = Pick File with Open(file_path, invisible):
dt_path = Pick File("Select JMP File",
	{"JMP Files|jmp"}
If(!IsMissing(dt_path),
	dt1 = Open(dt_path, invisible);
View more...
nw = New Window("New window",
	<<modal(),
	Text Box(
		"Tests",
		<<Set Font Style("Bold"),
		<<Set Wrap(1000)
	Spacer Box(Size(20, 20)),
	H List Box(
		Panel Box("Input JMP file",
			Button Box("Select file",
				{"JMP Files|jmp"}
				,<<setIcon("ListItemAdd")
	Spacer Box(Size(20, 10)),
	Panel Box("Actions",
		H List Box(
			align(center),
			Button Box("OK",
				keep_going = 1;
				todo_list = my_cb << get selected;,
				<<setIcon("CheckCircle")
			Button Box("Cancel", keep_going = 0, <<setIcon("ErrorSmall"))
	<<Size Window(340, 430)
wait(2);
dt = Open();
	{"JMP Files|jmp"}
View more...
	<<modal(),
	Text Box(
		"Tests",
		<<Set Wrap(1000)
	H List Box(
				{"JMP Files|jmp"}
		H List Box(
			align(center),
			Button Box("OK",
				keep_going = 1;
Jackie_
It worked. Thanks @jthi :)
Jackie_
Hi @jthi , Quick question. I am trying to bring the variability chart window in the front or maximize it after clicking on button box "Plot". I tried using bring window to front but it's not working. Can you suggest what other syntax can be use?
Here's my script:
dt2 = Open( "$SAMPLE_DATA/Big Class.jmp" );
	<<modal(),
	Text Box(
		"Tests",
		<<Set Wrap( 1000 )
	H List Box(
				dt_path = Pick File( "Select JMP File", "", {"JMP Files|jmp"} );
				If( !Is Missing( dt_path ),
					dt1 = Open( dt_path, invisible )
	V List Box(
		aa = Panel Box( "Variablity chart",
			Button Box( "   Plot   ",
				vc = dt2 << Variability Chart(
					Y( :height ),
					X( :sex ),
					Analysis Type( "Choose best analysis (EMS REML Bayesian)" ),
					Show Range Bars( 0 ),
					Std Dev Chart( 0 ),
					Points Jittered( 1 )
				aa << close window;
				vc << Show window( 1 );
				<<setIcon( "VariChart" )
		H List Box(
			align( center ),
			Button Box( "OK",
				keep_going = 1;
			Button Box( "Cancel", keep_going = 0, <<setIcon( "ErrorSmall" ) )
I think you started new topic related to this question (Bring window to front) , so we can continue discussion there, most likely related to you using modal window.
