gow
gow
Open all txt files in a folder, concat the data in to one file with source name
I am trying to open set of text files from a folder and concatinate the data in to one file, with name of txt file as one of the column.
I have attached code which opens all the text files in a selected folder. However, i am not able to create the column with file name.
can anyane help in script for isereting data (values) in to a column of a data table.
thaks
gowri
ms
Super User (Alumni) ms
Re: Open all txt files in a folder, concat the data in to one file with source name
This should work (edided excerpt from your script)
name = Left( y[1], Length( y[1] ) - 4 );
Open(
  "C:jmp\" || y[i],
  columns( Acct num = Character, . = Omit ),
  Import Settings(
  End Of Line( CRLF, CR, LF ),
  End Of Field( Comma ),
  Strip Quotes( 1 ),
  Scan Whole File( 1 ),
  Labels( 0 ),
  Column Names Start( 1 ),
  Data Starts( 1 ),
  Lines To Read( All ),
  Year Rule( "10-90" )
) << New Column( "source", character, set each value( name ) );
Only change is the placement of and the code inside New Column().
But you can also use the "Create source column" option of Concatenate() instead of adding a new column to each table.
Try the script below. an alternative approach to this problem that also lets the built-in functionalty of Concatenate() handle the source column.
mypath = "C:\jmp";
y = Files In Directory( mypath );
//remove all non-text files from y
For( i = N Items( y ), i > 0, i--,
  If( Ends With( y[i], "txt" ),
  Remove From( y, i )
n = N Items( y );
//Make list y1 of open() expressions
y1 = {};
For( i = 1, i <= n, i++,
  y1[i] = Parse(
  Eval Insert(
  "Open(mypath||\!"^y^\!",columns(Acct num = Character, . = Omit ),
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 0 ),
  Data Starts( 1 ),
// (Open and) Concatenate files
Eval( y1[1] ) << Concatenate(
  Eval List( y1[2 :: n] ),
//Close sub-files
  Close( Data Table( y[i] ), nosave )
ms
Open(
  "C:jmp\" || y[i],
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 0 ),
  Data Starts( 1 ),
mypath = "C:\jmp";
  Remove From( y, i )
n = N Items( y );
y1 = {};
  y1[i] = Parse(
  Eval Insert(
  Import Settings(
  Strip Quotes( 1 ),
  Labels( 0 ),
  Data Starts( 1 ),
//Close sub-files
gow
gow
Thanks this was very helpful
jorgeramosdealm
You can also do it with this script that is an alteration from
//Jump into JMP Scripting
//By: Wendy Murphrey and Rosemary Lucas
// http://www.sas.com/apps/pubscat/bookdetails.jsp?catid=1&pc=61733
//Page 122, Soultion 5.16
In order to incorporate the source file name.
Also a thread here
I also incorporated some things from MS answer. MS, I was unable to use your script to finalize the concatenation.
mypath = "C:\jmp\";
Set Current Directory( mypath );
  Remove From( y, i )
n = N Items( y );
For( i = 1, i <= N Items( y ), i++,
  sname=left(y[i],length(y[i])-4);
/* If the file is the first in the list, open it. Otherwise, open the table, concatenate with the main table, and close the table just opened. */
    If( i == 1,
        mainDt = Open( mypath || y[i] );
        mainDt << New Column ("source", character, set each value ( sname )),
        dt = Open( mypath || y[i] ) ;
        dt << New Column ("source", character, set each value ( sname ));
        mainDt = mainDt << Concatenate( dt, Append to First Table );
        Close( dt, NoSave );
        Wait( 0 );
/* Give the final table a name. */
mainDt<< Set Name( "Concatenated Files" );
