Setsuna
Open a .jrp file with JSL, but the open function returns nothing
Hello, I met a problem that confused me so much.
When I open a .jrp file using Open() function, nothing is returned.
rp = Open("<PATH-TO-FILE>\RxOsnrTol-01-Distribution-By(Temperature).jrp");
Show(rp);
Then in the log window, I got:
{Distribution[], Distribution[], Distribution[]}
rp = .;
By the way, the .jrp file is opened and displays normally. It seems that the only problem is the return value is missing.
The .jrp file is saved earlier with embeded data table.
I'm sure that I used the same code several days ago on some other jrp file, the Open() function returns an object. So I'm able to save its picture.
So I'm confused.
JMP Version: 16.2
If any further information or attachment is needed, please tell me.
Thank you very much.
===== Update =====
I attached a very simple example which shows the same problem.
For me, the log shows:
Distribution[]
Open(".\abc.jrp") = ␀;
10 REPLIES 10
Re: Open a .jsl file with JSL, but the open function returns nothing
To add to my previous update, it does look like there are differences in behavior between JMP 16 and JMP 17 as well.  Changes are being made for future releases to improve both the save and open behavior for .jrp files.  You best workaround for now might be to use Current Report() to get the window for the recently opened report.
