Georg
Open Excel File in Excel (Windows standard application) by JSL
Dear all,
my JMP should host a toolbox with also Excel and other files,
so I need to open a file by another application from my Windows system (JMP Pro 15.1, Win10).
Most preferably I would use that standard application that is used by windows explorer, when opening a file.
The example below opens the xls in JMP, I would like to open it in Excel, does anyone know how to accomplish that?
Thanks in advance!
cdt = Open( "$SAMPLE_DATA\Big Class.jmp" );
xls_path = Convert File Path( "$TEMP\Big Class.xls" );
cdt << save as( "$TEMP\Big Class.xls" );
// open file in Excel application, not in JMP, how to ?
open(xls_path, /*Excel Wizard*/);
Georg
Mauro_Gerber
Level V
Re: Open Excel File in Excel (Windows standard application) by JSL
Be aware to avoid spaces in the file name, otherwise the argument must include "path" in the string (so double")
xls_path = Convert File Path( "$TEMP\Big_Class.xls" );
cdt << save as( "$TEMP\Big_Class.xls" );
RP = Run Program(
	Executable( "C:\Program Files (x86)\Microsoft Office\Office15\excel.exe"/*path to excel, you may search it in the registration entry of microsoft*/ ),
	Options( {"/r",SUBSTR(xls_path,2)} ),
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
Using the Web() function is a quick and easy way to open an external file in it's assigned application
web("$TEMP\Big Class.xls");
Mauro_Gerber
Level V
RP = Run Program(
- GLaDOS
Georg
Thanks @Mauro_Gerber and @txnelson for the proposals. In my case "run program" did work after some correction of the path string (fileshare starting with // on windows 10), the proposal with "web" did not work, I tried several times, it looks elegant.
I'm not sure, why, couldn't find anything in the log ..., simply no Excel started (Win10, Office16).
Georg
SeriyGena
Hello, i have similar, but not the same case. I already have the source file in xlsx format, and it includes multiple tabs.
I would like to have script that opens it as read only or its copy (copy is the best option) in excel.
My version of Win10 and in Win11 the is no option to this:
excel located at C:\Program Files\Microsoft Office\root\Office16\EXCEL.EXE
But excel alarm appeared with the meaning, that it can't find the filefile.pngfile.png
path="my_excel_file_absulute_path";
RP = Run Program(
	Executable( "C:\Program Files\Microsoft Office\root\Office16\EXCEL.EXE"),
	Options( {"/r",path} ),
