One-tail vs. Two-tail tests
I am doing the means comparison using one-way ANOVA in Jmp. When I look at the detailed report, I see the p-values for both one-tail and two-tail t-tests.
However, the comparison circles seem to display according only to the two-tail confidence levels. The same about LSD (least significant difference) - it is calculated only for the two-tailed test.
Question: can I change it somewhere so that one-tail test will be used as default? If not, can I get the circles and lsd values for one-tail test somehow?
Thanks,
Mike.
10 REPLIES 10
Re: One-tail vs. Two-tail tests
OK. You're right.
Thanks.
