ray3
Obtaining file date (created/modified) information in JSL
I was wondering if it is possible to obtain the date created/date modified information from files using jsl.
I have a large data directory that stores all the raw data from experiments run in the lab, and I would like to load the entire directory and be able to plot files based on the date they were created to get a historical trending, without having to open them individually
Thanks
Ray
pmroz
Re: Obtaining file date (created/modified) information in JSL
You could dynamically create a bat file with the command
dir/a-d (your directory here) > tmp.txt
Execute the bat file using Open(). See this thread for more details: http://support.sas.com/forums/thread.jspa?messageID=33589茵
Then read the file tmp.txt into JMP. Not a gold watch, but it'll work!
Regards,
Peter
ray3
Working is what I need!
and it does.
Thanks.
