JMPUser9
Number by Count in Other Columns
I want to create a formula in a new column, Run Number, to count based off other columns. For example:
Sample     Test      Run Number
A                one      1
A                one      2
A                two      1
A                two      2
B               one      1
B               two      1
C               one     1
C               one     2
C               two     1
C               two     2
Re: Number by Count in Other Columns
Using Col Cumulative Sum() is one option
Col Cumulative Sum(1, :Sample, :Test)
Col Rank() is also an option
Col Rank(:Sample, :Sample, :Test)
Full example with your table
dt = New Table("Untitled 2",
	Add Rows(10),
	Compress File When Saved(1),
	New Column("Sample",
		Character,
		"Nominal",
		Set Values({"A", "A", "A", "A", "B", "B", "C", "C", "C", "C"})
	New Column("Test",
		Character(16),
		"Nominal",
		Set Values({"one", "one", "two", "two", "one", "two", "one", "one", "two", "two"})
	New Column("Run Number",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([1, 2, 1, 2, 1, 1, 1, 2, 1, 2])
dt << New Column("RN", Numeric, Ordinal, Formula(
@JMPUser9 ,
@jthi has provided an excellent answer.
However, the answer to this question has been answered multiple times before in the Discussion Community.  I request that before a request is submitted that a search is made to the past Discussions.
I did a search on "Count" and it returned several related responses.
Thank you
