ScrivensL
Nonlinear Fit SSE Grid Scripting Syntax
I'm using JMP 17.2 and I can't find much information online with how to script an SSE Grid using the nonlinear tool under 'Specialized Modeling'. I can see from the scripting index the below, but I can't see how to set the min, max, and number of points programmatically via the scripts. Is someone able to explain the syntax that can be used with SSE Grid with an example of setting the parameter min, max, and number of points?
dt = Open( "$SAMPLE_DATA/Nonlinear Examples/CES Production Function.jmp" );
obj = Nonlinear( Y( :"log($ value)"n ), X( :Model ), Finish );
obj << SSE Grid;
Re: Nonlinear Fit SSE Grid Scripting Syntax
I'm not sure if there are any other options than setting the values directly to the number col edit boxes and then "clicking" the button
dt = Open("$SAMPLE_DATA/Nonlinear Examples/CES Production Function.jmp");
obj = dt << Nonlinear(Y(:"log($ value)"n), X(:Model), Finish);
obj << SSE Grid;
ob = Report(obj)[OutlineBox("Specify Grid for Output")];
tb = ob[Table Box(1)];
mins = {0, 1, 2, 3};
maxs = {1, 2, 3, 4};
points = {10, 12, 13, 14};
tb[2] << Set(mins);
tb[3] << Set(maxs);
tb[4] << Set(points);
ob[Button Box(1)] << Click(1);
obj << SSE Grid;
tb[2] << Set(mins);
tb[3] << Set(maxs);
