There is a little syntax error in this section of the code:
fred=r[outlinebox("Linear Fit"),Outlinebox("Parameter Estimates"),ColBox("Estimate")[1]]<<get(1);
The column box reference is a number column box in the report, so try using NumberColBox. Also, Put the reference of the first value inside the () instead of outside and remove the [ ]. Put a comma between the title and the number reference. See below
fred=r[OutlineBox("Linear Fit"),OutlineBox("Parameter Estimates"),NumberColBox("Estimate",1)]<<get(1);
That should work for you.
Best Regards,
Chris Kirchberg
Chris Kirchberg, M.S.
2Data Scientist, Life Sciences - Global Technical Enablement
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail:
[email protected]www.jmp.com
