trevorphysics
New column to label positive or negative
I have data in column :direction that is either positive, negative, or blank determined by a Lag formula 'in the column.
I created a new column :updown where I wanted to look at row of :direction. If it's positive or blank, I want updown for that row to be "Up", otherwise I want it to say "Down". This will simplify data filtering since we just want to split up multi-directional voltage data.
//Check Whether positive or negative
For(i=1, i<=N Rows(dt), i++,
if(:direction[i] < 0,
 :updown[i] << Set Value("Down");,
 :updown[i] << Set Value("Up");
I've done something similar previously but it doesn't seem to be working. I've tried a few different syntax options and nothing has worked.
Thanks in advance for your help!
SamGardner
Re: New column to label positive or negative
I think you just need to  do this
 :updown[i] ="Down";,
 :updown[i] = "Up";
An alternative is to use a formula
column(dt, "updown") << Set Formula( If(:direction <0, "Down", "Up"))
SamGardner
 :updown[i] = "Up";
