wjalford
Need to compare result from one table with spec limit in another table. If result < limit then pass
I have a table (Limits) with the limits.  The table columns are Product, Componet A, Componet B.  Under each componet is the limit.  Example Product, Aluminum, Zinc
                                                         Fudd         .24        .50
I have another table FG Metals that has a PASS/FAIL column and a Aluminum column and a Zinc column with the results in each row.  Example PASS/FAIL, Aluminum, Zinc
        .09        .1
I need to compare the dt(FG metals) Aluminum .09 result with the dt(Limits) Aluminum .24.  If result is less than limit then put Pass in the PASS/FAIL column otherwise put FAIL.
Hopefully I explained this well enough.  Please let me know if you have any questions.
Wayne
21 REPLIES 21
Re: Need to compare result from one table with spec limit in another table. If result < limit th
Try changing the line of code to
Column( colNamesList[theColumn] || " PASS/Fail" ) << delete property("formula");
HSS
HSS
Level V
It worked.
Many Thanks.
