pauldeen
Name quote a strange column name
I'm trying to insert a column name into a fit model expression. For that I need to escape strange characters in column names to do that we use the :"name"n convention. So how do I go from a string column name to this format?
colListY = {"Plating Thickness (m\!"\!")"};
//This doesn't work
newcolumnref = eval insert("\[:"^colListY[1]^"n]\");
//Looking for this end result
:"Plating Thickness (m\!"\!")"n
Which I can then insert anywhere, for example:
insert into(expr(Y()), newcolumnref);
Anybody know of a robust way to do this?
22 REPLIES 22
hogi
Level XIII
Re: Name quote a strange column name
dt = New Table( "plating",
	Add Rows( 4 ),
	New Column( "Plating Thickness (m\!"\!")",Set Values( [1, 2, 3, 4] )),
	New Column( "X",Set Values( [12, 26, 33, 39] ))
newcolumnref = Name Expr(AsColumn(colListY[1])); // -> :"String"n
Fit Model( //Y( :"Plating Thickness (m\!"\!")"n ), <- works //Y(column("Plating Thickness (m\!"\!"")), //<- does not work Y(newcolumnref), // <- works :) Effects(:X), Personality( "Standard Least Squares" ) );
from
https://community.jmp.com/t5/Discussions/Need-help-with-expressions-column-references-formulas-and-c...
	New Column( "Plating Thickness (m\!"\!")", Set Values( [1, 2, 3, 4] ) ),
	New Column( "X", Set Values( [12, 26, 33, 39] ) )
col = Column( dt, "Plating Thickness (m\!"\!")" );
Fit Model(
	Y( col ), // <- works :)
	Effects( :X ),
	Run
hogi
Level XIII
@Mark_Bailey
Ah, so easy! great!!!
I was surprised to hear from @pauldeen :
https://community.jmp.com/t5/Discussions/Name-quote-a-strange-column-name/m-p/415735/highlight/true#...
that
when building the fit model script the column() format cannot be used:
Fit Model(
OK, if it's like this, what would be the easiest solution to get the column without column() ...
Now I was surprised to see (by running your code) that it actually worked.
And went back to the old sniplet - and it didn't work.
Woah!
The puzzle gets solved if you put both lines of code exactly below each other:
-> So fortunately, no fancy non-Column() coding required for Fit Model.
