Bluebird73
Name Unresolved for column name when using Match function
Hi, I have a script that pulls a query then I attempt to recode some of the query information. whenever I run the "match" function in a separate script it works but when I combine it into my full script I get the error: "Name Unresolved: SamplePoint at row 1 in access or evaluation of 'SamplePoint' , SamplePoint/*###*/"
SamplePoint is the column I'm trying to recode
Here is the full code:
delete symbols();
//function to pull data based on analysis
AnalysisData = Function( {analysisinput},
	New SQL Query(
		Connection( <ommitted> ),
		QueryName( "TEST" ),
		Select(
			Column( "ANALYSIS", "t1" ),
			Column( "VALUE", "t3" ),
			Column( "Z_TRIAL", "t2" ),
			Column( "NAME", "t3" ),
			Column( "ID_NUMERIC", "t2" )
		From(
			Table( "TEST", Schema( "dbo" ), Alias( "t1" ) ),
			Table(
				"RESULT",
				Schema( "dbo" ),
				Alias( "t3" ),
				Join( Type( Left Outer ), EQ( Column( "TEST_NUMBER", "t1" ), Column( "TEST_NUMBER", "t3" ) ) )
			Table(
				"SAMPLE",
				Schema( "dbo" ),
				Alias( "t2" ),
				Join( Type( Left Outer ), EQ( Column( "SAMPLE", "t1" ), Column( "ID_NUMERIC", "t2" ) ) )
		Where(
			In List(
				{analysisinput},
				UI( SelectListFilter( ListBox, Base( "Categorical" ) ) )
			) & Custom( "ID_NUMERIC > 15012", UI( Custom( Base( "Categorical" ) ) ) )
	) << Run
); // end of function
//function to format data
FormatTrial = Function( {dt},
	dt33 = dt << Split(
		Split By( :NAME ),
		Split( :VALUE ),
		Group( :Z_TRIAL ),
		Remaining Columns( Drop All ),
		Sort by Column Property
	Close( Data Table( "TEST" ), NoSave );
	Wait( 3 );
// new column for trial id
	dt33 << New Column( "Trial ID", Character, Formula( Left( :Z_TRIAL, 4 ) ) );
// new column for sample location
	dt33 << New Column( "SamplePoint", Character, Formula( Right( Left( :Z_TRIAL, 8 ), 3 ) ) );
	:SamplePoint << Delete Formula;
// new column for sample number
	dt33 << New Column( "Sample #", Character, Formula( Right( :Z_TRIAL, 3 ) ) );
	:"Sample #" << Delete Formula;
// move new columns to left
	collist = {"Trial ID", "SamplePoint", "Sample #"};
	dt33 << Move Selected Columns( collist, To First );
	dt33 << select where( Is Missing( :"Trial ID" ) );
	dt33 << Delete Rows;
);// end of function
//function to recode columns
SampleInfo = Function( {dts},
// recode the sample location
	For Each Row(
		SamplePoint = Match( SamplePoint,
			"100", "RP",
			"101", "RCP",
			"102", "RL",
			"103", "RCL",
			"104", "RLM",
			"105", "FTR1",
			"106", "FTR2",
			"107", "FTR3",
			"108", "FTR4",
			"109", "ML",
			"110", "M1",
			"111", "M2",
			"112", "MW",
			"113", "M2W",
			"115", "DCt",
			"116", "DCr",
			"117", "DE",
			"N/A"
fai = "TM-006";
AnalysisData( fai );
dt10 = Current Data Table();
dt10 << Row Selection(
	Select where( :NAME == "Span" | Contains( :NAME, "Check D" ) ),
	Match case( 0 ),
	Dialog( Edit( Equal( Source Column( :NAME ) ) ) )
dt10 << Invert Row Selection << Delete Rows;
FormatTrial( dt10 );
//psa formatting
dt33:"Check D10 (avg of 5 replicates)" << set name( "d10" );
dt33:"Check D50 (avg of 5 replicates)" << set name( "d50" );
dt33:"Check D90 (avg of 5 replicates)" << set name( "d90" );
dt33:"Check Dmax (avg of 5 replicates)" << set name( "dmax" );
dt33:"Check Dmin (avg of 5 replicates)" << set name( "dmin" );
dt33 << Set Name( "PSD Data" );
SampleInfo( dt10 );
Re: Name Unresolved for column name when using Match function
I think this may be a scoping issue.  Try placing a ":" (colon) in front of SamplePoint whenever you are referencing it as a column name.
Note:  Please enter JSL by using the JSL icon at the top of the Preview Window.  It allows for readers to more easily read the code.
