Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
anne_sa
Multiple comparison test for qualitative variable
Hello everybody,
I would like to know if it exists an equivalent of the Tukey's test but for a qualitative response (i.e . after running a nominal or ordinal logistic regression).
Thanks
Raaed
Re: Multiple comparison test for qualitative variable
Řaëd ~✍
anne_sa
Hi @Raaed
Thanks for your answer but actually I am looking for something similar with a nominal or ordinal response, instead of a continuous one, like in your example.
Any idea ?
Please look at this portion of the JMP Help to see if this approach is useful.
anne_sa
Hi @Mark_Bailey ,
I didn't know this option which can indeed be very useful!
However if I understand correctly it works only if the response has to levels. Moreover in my case,  what I have in mind is to compare pairwise the levels, but I don't know if it is feasible
Yes, this method depends on a dichotomous response. Yes, it compares each level to the overall proportion, not one level to another level.
