marcovang
Mixture profiler with 1 variable being 0.1%, 0.4% and 1%. How do i magnify the interesting part of the ternary plot in the mixture profiler?
Using JMP 18 (now switched to JMP 19)
Victor_G
Re: Mixture profiler with 1 variable being 0.1%, 0.4% and 1%. How do i magnify the interesting part of the ternary plot in the mixture profiler?
Hi @marcovang,
Welcome in the Community !
Is the area small because of mixture factors ranges you're interested in, or do you want only to zoom in ?
  1. In the first case, make sure your mixture factors columns have the right column properties for their role: Mixture, Design Role and Factor Changes. Particularly, PseudoComponent Coding should be used and checked if the mixture sum is above 0 or less than 1. It will indicate to Profilers the area of interest automatically.
  2. In the second case, you should be able to move the ternary plot to the area you're interested in by moving your pointer near the axis/borders. Once you got a hand icon, press click and move the axis to the right or left to zoom in in the ternary plot.
Hope this answer will help you,
Victor GUILLER
Victor_G
Hi @marcovang,
Victor GUILLER
marcovang
Thanks Victor.  It was number 2 and it solved it.
You can also use one of the interactive graphics tools: the Magnifier. You can find it in the Tools menu or the toolbar. Here is the background information about how to use it: Magnifier.
